As mentioned... I'm thinking of changing my GPU's.
System specs currently...
2 x Inno3D iChill Herculez 780's in SLI
AX-1200i PSU,
H100i cooled 3930k CPU,
ASUS P9X79E-WS mobo,
16GB Avexir Quad 2400mhz
500GB SSD
2TB HHD
CoolerMaster Cosmos II case
Running a ASUS VG278HE 27" 144Hz 3D LED 1080p monitor and a Samsung 27" S27B970D 1440p PLS monitor.
So there's plenty of space and general grunt to run the latest GPU's in...
I have been thinking about moving to a pair of Inno3D "Herculez X3 Ultra" 980's instead which come in at £800 a pair currently.
They look very much the same as my current 780's which I actually really like and I may even be able to swap backplates out on my top slot GPU which I had to modify slightly in order to fit the 3 slot card on the mobo's top PCI slot.
(took a small 5mm deep x 15mm long slither off the bottom edge of one backplate to fit over a heatsink more comfortably)
But the new TitanZ pricing has got me considering a single EVGA GeForce TitanZ at £1199. More CUDA cores and 12GB of memory are making me think of the long term power benefits...
(Also with the thought of adding a second TitanZ about 6 months or so down the line)
My budget is fine for both options right now and although I'm not at the moment, eventually I'm going to take the plunge for a 4K monitor set-up.
Just waiting for that perfect monitor deal!
So thoughts guys please?
Put yourself in my shoes with this current system and would you go all out and jump on a TitanZ?
Maybe prompting you to double up later to TitanZ SLI...
Or just move from a pair of 780's to a pair of 980's and be done with it?
Cheers in advance for your thoughts!
AX-1200i PSU,
500GB SSD
2TB HHD
