- 27 Apr 2009
Hey guys! It's that time again... I love this part
ADVICE NEEDED ON UPGRADING GAMING PC!
Current specs:
i7-2600 3.4ghz
24GB Teamgroup RAM (don't ask)
Gigabyte Z68XP-UD3
1TB HDD partitioned 50/50 half OS+files and half game files
ASUS GTX560Ti
Corsair GS700 (practically brand new)
This is my friend's system and I have some ideas to upgrade it (namely wait for GTX800 series then buy a 770 and upgrade CPU and mobo. Also get an SSD for OS and keep game install files on the current 1TB drive)
However I just wanted to put it to you guys to see what you think, upgrade budget is about £500-600 although not strictly limited, just ideally within that.
GPU definitely is struggling now with Far Cry 3 really cooking it, and with GPU upgrade new CPU is likely needed right? I'd like to keep it Intel+nVidia because in my experience that just seems to work a bit better... AMD alternatives welcome though!
Look forward to your thoughts.
Thanks!
Current specs:
i7-2600 3.4ghz
Gigabyte Z68XP-UD3
ASUS GTX560Ti
Thanks!
