- 15 Mar 2007
Got a 3080 and going to put a 4070 TI in its place - you guys remove drivers first or not bother ?
Display Driver Uninstaller. Free software for removing NVIDIA/AMD drivers.DDU?
Display driver uninstall software.DDU?
Assuming the 3080 is on a recent driver, then no need to uninstall, as they both use the same drivers.Yeah it will be different drivers. Uninstall drivers, turn off, install 4070, restart and install new drivers.
Display Driver Uninstaller.DDU?
While unlikely in this case AFAIK, the same version, date and file size does not meant that the same thing gets installed as the installer could use different settings depending on what it detects or even extract different binaries from the installation archive. The ultimate example would be installing Windows from an ISO. Same ISO, potentially different HALs (but Windows has got a lot better at that), etc.Assuming the 3080 is on a recent driver, then no need to uninstall, as they both use the same drivers.
Don't believe me - try it, Go to NVIDIA's site and select either the 3080 or the 4070Ti and both come back with the same version, date and filesize
Driver Details | NVIDIA
Download the <dd~LanguageName> <dd~Name> for <dd~OSName> systems. Released <dd~ReleaseDateTime>www.nvidia.co.uk
Used to be needed ages ago when removing display drivers would leave old files, profiles and things laying around, but these days drivers from both NVIDIA and AMD are much better.
It's not really needed, and arguably is more of an inconvenience as it resets everything, so any changes you've made in the graphics driver need setting back up again
It should work fine - upon first boot with the new card Windows will detect it, and then just need a reboot - then all should work fine.yer, thanks. I will try it without uninstalling the current drivers.
From experience though it isn'tPretty sure that isn't the case with Nvidia's drivers, but it could be.
