Hi all.
After getting a lot of help when I was building my 1st machine back in 2009 and after checking back here from time to time. I think it's now getting close to the time to upgrade my kit.
Advice is badly needed. My current computer is working fine but as an avid gamer I have now had to start reducing my settings and cutting things out to get the frame rates I need. That obviously is not ideal. This upgrade is going to be in two parts. The 1st part mid July and the 2nd part Jan/Feb next year. I could squeeze some stuff inbetween but as thats when I get my bonuses so thats when I plan to buy.
My current set up is this:
Intel i5 750 2.66ghz @4.00GHZ
Gigabyte GA-55-UD5 P55 Motherboard
Corsair XMS3 4gb (2x2GB) PC3-128009 1600MHz DDR3
Sapphire ATI Radeon HD 5870 1024MB GDDR5
Corsair H50 CPU Watercooler
Silverstone Fortress FT01S-W Mid Tower Case Silver Aluminum with Window
Pretty standard 500g hard drive + external storage drive
22 Asus LCD (3 years old & cheap at the time)
keyboard & mouse new (so no need to change)
My budget is pretty fluid. I have been looking at set ups including monitor that break 2k. But in reality I think around 1500 mark is probably realistic, although if the upgrade/new build is worth it then I could stretch. As this will be in 2 parts, I need upgrades that fit easily into my current set up in July then the rest in Jan (I assume the case, mobo etc will be then).
Things that I am not that flexible with (still up to suggestion though):
The case must be of a similar style to the FTO1 with a left hand window, no piles of plastic and must be a good air cooler (be nice to be able to access the top filter this time to).
Need a 120g Solid state hard drive or better (no clue on the differences though)
The monitor must be 24" or 27" and great for gaming.
The graphics card would need to be a 580 or similar but have no clue about the differences in makes.
Like the H50 so a similar new version would be great.
Thanks in advance for any help I get. My 1st build went very smoothly as a result of people here. I hope my upgrade goes as well
