Hi, I have a laptop computer running XP Home SP2 which has 512MB DDR SDRAM (200pin, gold pins, SO-DIMM modules) (2 x 256MB modules), and I want to upgrade it to as much memory as it can handle. The specs are :-
Intel P4 2.6GHz Northwood
Chipset SiS 645DX (supports max 3GB memory)
BIOS Insyde 28 Aug 2003
NVidia GeForce4 440 Go 64MB
mobo = Mitac MTC 8640
The model is Evesham Voyager 5815+2.6SEP03 WO01030028.
There seem to be 2 DRAM slots in it for 2 SO-DIMM 200-pin modules, and I am wondering if I can put 1GB stick in each one ?
I've searched on Google but can't get the definitive specs for this mobo, so I'm not even sure if there's maybe a 3rd DRAM slot somewhere. Does anybody know what size of memory sticks this system will take, or where I might find out ?
I've looked on MITAC website but can't see any way to contact them and registration on their site doesn't seem to work.
Many thanks for any advice.
