Upgrading! lil help needed
19 Feb 2011
Liverpool,UK
So i built a new system in March for my 21st and i still have lil things to iron out, My case is a hand-me down which is a "AeroCool AeroEngine II" lil on the old side and a bit battered, Ive been holding off on going Crossfire for awhile but still really want to do it but im not sure if my Mobo will be 100% suitable for it because of the PCIE placement.
Case replacement which looks amazing and i think im sold on that tbh.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-024-NX
My old mobo - Running like a trooper full power from the PSU with 8 pin power and overclocking my CPU more than i could have wanted.
http://www.overclockers.co.uk/showproduct.php?prodid=MB-034-AK&groupid=701&catid=1903&subcat=
Mobo replacement if needed- Nice spread on the PCIE arrangement to allow space between the CF cards.
http://www.overclockers.co.uk/showproduct.php?prodid=MB-398-AS
If my mobo is suitable, ie the temps will be good then il ditch the new mobo idea and grab a nice SSD for the same price :)
Any help would be greatful!
Your current motherboard is not ideal as:
a) The 2 green and orange x16 (physical) PCI-E slots are close together which is poor for cooling
b) The orange slot only runs at x4 speed
as the above poster said, you will want the motherboard replacement.
normally i would say to not go for the motherboard you have chosen because you only neex x8/x8 crossfire, but at that price theres no reason not to
(get it quick because the deal will end on tuesday night)
Thanks for the speedy reply Surveyor, i thought as much being the Cards would be kissing in CF which i dont want, i want them as cool as possible.
again thanks :) time to buy
