Upgrading my lads rig
27 Nov 2011
He has an old machine, for gaming and a bit of homework. Doesn’t play anything crazy demanding but I would like him to benefit from the 27in 1440p 144hz screen I am going to gift him soon. His is a hand hand me down from my partner. Stats are.
FX-4300 4-Core
8GB (1x8) DDR3 RAM (803mhz)
970A-DS3P Motherboard
2GB Radeon R7 370 GPU
I’d like to upgrade the CPU and the GPU, with a concern that the Mobo will only take so much for its socket and dont have the right advice to know what would work for an upgrade.
As far as I can tell, the bottleneck here is the CPU rather than GPU.
best upgrade I can see here is an fx-8370 (which should be best for the socket) at around £130 and then for the GPU, the most I reckon I could upgrade without having another cpu bottleneck would be an RX 590 at about £140
So the biggest questions I have would be
a) is there a better CPU to put on that mobo that beats a 8370?
b) assuming that is the best mobo, is the RX 590 a reasonable upgrade that won’t get bottlenecked by the CPU?
c) for the cost of a new case, ram, psu and such being negligible as far as budget goes (ie I wouldn’t factor it into my decision), would I be better finding a Ryzen option for £100-200 on a new mobo build that would be better for gaming for him rather than upgrading?
I am deciding if his old machine is just too old to upgrade any more and build him one from scratch, or if I can eek out some more life from it with a cpu upgrade. I don’t mind spending the money to build him a new machine if I need to, money isn’t as much of an issue as is if I am being wasteful by not taking advantage of the current option
I'd pick up a cheap B450 or A520 and a ryzen 3100/3600 although you would need some ram but you would be looking at about £220-280 for those parts
A 590 would do a job a 1440p but you would need to turn down the settings to get close to 144hz.
You might be able to use your existing parts like SSD/hdd case and psu to save on cash etc.
As a cheaper alternative to the above.
I think throwing £130 on a FX 8370 is dead money its just not worth it. £50 maybe.
You can pickup a Ryzen 3 3200g for £95 if you shop around in stock just as an example which is a lot quicker and under your CPU budget!
Pickup something like a B350 board (OCUK have them for £50 b grade) for the 3200g thats £145 for a modern CPU with a GPU and a Motherboard!
8gb DDR4 about £40-50
16gb DDR4 RAM set you back about £50-£65
Then look for a graphics card, dont forget 2nd hand. eg 1060 6gb are going for around £100-£120 might even be able to get a GTX 1070 for £150 ish
Might get £50 back for selling your old kit 2nd hand too.
So as you can see makes the £130 for the FX 8370 poor value.
You can pickup a Ryzen 3 3200g for £95 b
Why would you pay £95 for a 4/4 old Zen + cores APU when you can get the 3100 which is 4/8 zen 2 cores for 5 quid more especially when it's going to be used with a GPU.
Also with A520 boards starting at just over 60 quid and offering full warranty and a future upgrade path to zen 3 there is absolutely no point spending a tenner less on a 3 year old motherboard with just 3 months warranty.
My basket at Overclockers UK:
Total: £72.49 (includes shipping: £10.50)
Why would you pay £95 for a 4/4 old Zen + cores APU when you can get blah
You could have said why waste £130 on a 8370 ?
It was an example not a solution to show the £130 for a 8370 was a waste of money. You example said £220-£280. My example was about £145. I didn't look extensively. If the person only has £150 to spend on mb/CPU then your example is over budget. The 3100 is another alternative I've seen it for £90. Chill man.
Yes, complete replacement of the CPU, motherboard, and RAM. And don't worry about bottlenecks: at your price point it's all good.
Total: £510.06 (includes shipping: £11.10)​
Do look at Intel CPUs: they're cheaper and faster for gaming.
Total: £474.45 (includes shipping: £10.50)​
(The AMD CPU comes with an adequate cooler; the Intel CPU does not.)
Thanks for the helpful advice. I agree that a fresh build is probably a better idea. Case is a bit ugly, old and I am sure the PSU is probably Bronze or similar so starting from scratch could be a good idea.
It was nothing personal I was just merely pointing out that making a saving of £17 on a old B-grade board and the APU was not worth with it over the newer stuff.
Of course the the 8370 is terrible value and that's why I never suggested it as an option.
