- 21 Mar 2008
Hello all,
Current spec is as follows, built a couple of years ago following advice on here:
Leadtek GeForce 8800 GT 512MB GDDR3 HDTV/Dual DVI (PCI-Express)
Intel Core 2 Duo E8200 LGA775 'Wolfdale' 2.66GHz (1333FSB)
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
Corsair TX 650W ATX SLi Compliant Power Supply (CMPSU-650TXUK)
Western Digital Caviar Blue 250GB SATA-II 16MB Cache - OEM (WD2500AAKS)
Corsair Dominator 2GB (2x1GB) DDR2 XMS2 PC2-8500C5 TwinX Dual Channel (TWIN2X2048-8500C5D)
Gigabyte GA-P35-DS3L Intel P35 (Socket 775) PCI-Express DDR2 Motherboard
I'm thinking about upgrading but I'm not sure what would make the biggest difference in terms of performance. It's used mostly for gaming (CoD, Need for Speed etc) so I'm guessing a new graphics card might be best. I've not really kept up to speed with developments so any advice would be good. Other than that I suppose the CPU is the next target?
Budget-wise I reckon couple of hundred quid might be possible? I'd like something that will last a few more years without upgrading again, plus I'm also tempted by Windows 7 and Just Cause 2....decisions decisions...
Cheers for reading.
Cheers for reading.
