Upgrading my OC desktop for the Oculus Rift advice
25 Jan 2016
Hi all,
I purchased my current desktop from OC in January 2014. It's been great, but I have a pre-order for the rift and am aware that I need to upgrade to meet the minimum spec.
This is what I own at present:
"Titan 420i Tanto" Intel Core i7 4770K @ 4.1GHz Overclocked
Haswell Quad Core Gaming PC
GX-182-GW Gainward GeForce GTX 780 Phantom 3072MB GDDR5
FS-187-OE No Sound Card Upgrade
HD-255-SE Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM
HD-168-SA Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic -
CA-129-NX NZXT Phantom 530 Full Tower Gaming Case - Black
SW-165-MS Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614)
FS-320-OE 24 MONTH WARRANTY - COLLECT & RETURN
XX-003-OP Standard Build Systems - Dispatched within 7 working days
CP-473-IN Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor -
MB-438-GI Gigabyte Z87-HD3 Intel Z87 (Socket 1150) DDR3 ATX Motherboard
HS-100-AK Akasa AK-CC4013EP01 Nero 3 V2 Premier CPU Cooler
CD-003-OK OcUK 24x DVD±RW SATA ReWriter (Black) - OEM
MY-094-KS Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9
CA-048-CS Corsair Builder Series CX 600W V2 '80 Plus Bronze' Power Supply
My questions are:
1. If I want to upgrade to a GTX 980 TI, do I also need to upgrade my 600W PSU? I have a feeling it may be too weak?
2. Do I need to upgrade my 8GB RAM?
3. Should I hold out for a couple of months to get a GTX 980 TI cheaper?
Thanks in advance for the advice!
The 600W should handle a 980Ti however it depends if your looking at over clocking the 980Ti? It will most likley be borderline of what the PSU can handle as it's only bronze rated.
Thanks very much for the replies.
Is it easy to switch out a PSU and replace it if necessary? I've never done it before.
Also, what would happen if the PSU can't handle the new GPU?
I want to get everything that needs upgrading done when the rift arrives, so I am good for at least the next couple of years.
I am only mildly experienced with tinkering with the innards of a PC (GPU and RAM).
So i'll wait to upgrade the GPU closer to the time of release - Thanks for the advice.
Replacing a Psu is pretty straight forward, use your mobo manual if you are not sure what leads go where. And if you don't have the manual, you can always download it from Gigabyte.
If you do decide to upgrade the Psu, look for a decent fully modular unit, cuts down on a lot of cable clutter.
I'd just try it, this what result I get from the Steam VR test, no idea how accurate it is but I'd class it as a pass.
I would recommend that you take a picture of your motherboard with the current PSU installed noting any points on the motherboard where a lead is connected. That way you can be sure when you change PSU that you don't miss a lead and then give yourself a lot of grief.
