upgrading my pc and using the spares to build another
20 Oct 2019
So a family member of mine has an incredibly slow pc that needs to be replaced. I was wondering how viable it would be to upgrade my own and use the leftover components to build a new one. they won't be using it for gaming but they want something easily upgradeable so they won't have to buy a new PC every few years.
For reference my pc has:
Ryzen 3700X Cpu with it's stock cooler
Radeon RX 5700 Gpu
B450 THMWK max motherboard
16GB patriot viper steel 3.6ghz Ram
Corsair RM 750 Psu
as well as a sabrrent rocket SSD for a boot drive
let me know if any more information would help. I haven't used this forum in a while
What do you use your PC for?
By "easily upgradeable" are they thinking of RAM and storage primarily?
Forgot to add a few points. My PC needs more RAM for the software i use (at least 32GB) . I would guess about £500 budget wise but maybe a little more i know this isn't a huge amount. absouloutely no more than £650 for the combined budget of both.
The PSU is from 2019 and still in warranty.
In terms of upgradeability it just needs to not be upgradaeable. Because their current PC has a very strange design and most components simply won't fit inside.
The SSD is 1TB
For that budget you could do a CPU upgrade, OR a GPU upgrade, but both would be very difficult due to high GPU prices.
I am very happy with my current GPU. If i were to ask a question how long would my current CPU and RAM be suitable for an everay windoews user before becoming too slow.
RAM is the primary thing i wish to upgrade. I was thinking of upgrading my CPU and motherboard as well if possible in oreder to use DDR5 RAM.
that's not a lot.
personally, this is what i'd do...
1) forget about "upgradeability" for your family member's pc...a decent ex-corp dell/hp/lenovo will do the trick for most things especially once you chuck in a ssd (+/- low power gpu if they game...something like a 1050ti/1650) in there
2) use the rest of your budget for yourself
a) things to sell: 3700x, 16gb ram, rx5700
b) things to buy: 5700x3d, 32gb ram (in a kit of 2x 16gb) ddr4, rx7800xt
you'll need to jump onto the am5 platform then
Gaming but also 3D moddeling, vector art as well as image editing and creating games.
Just using firefox right now and it
s Ram is half full
If i were to ask a question how long would my current CPU and RAM be suitable for an every windows user before becoming too slow.
If they just open like.. 2 browser tabs and turn off the computer? 10 years (exlc. Windows 11 being outdated). If they open a million tabs and never restart? 5 minutes.
hmmm...let me seee
family pc £250ish, leaving ~£400 budget, add 3700x/16gb/5700 ~£200
so approx £600 to play with, split into: 5700x3d £150, 32gb ddr4 £60, 7700xt £390 (spec 1)
if wanting am5, £400 + £250 after selling 3700x/b450/16gb/5700 = £650 budget
7600 £160, 32gb ddr5 6000 £110, b650 mobo £170...leaving £210 for the gpu...which will only get a 6600xt, which isn't a massive upgrade from the 5700 (spec 2)
if wanting am5 but keeping the 5700 = £400 + £140 = £540
7700 £290, 32gb ddr5 6000 £110, b650 mobo £170 = £570 (spec 3)
the am4 (spec 1) build will give a significant performance advantage because the 7700xt is 1.8x the gpu performance of the 5700
but am5 (spec 2/3) would provide better "upgradeability" over the next 2-3 years...if you plan to upgrade any further
the 6600xt is only 1.2x the gpu performance of the 5700...however more power efficient
s Ram is half full
RAM is the primary thing i wish to upgrade. I was thinking of upgrading my CPU and motherboard as well if possible in order to use DDR5 RAM.
The build below would give you 48GB of DDR5, but tbh, if you all you need is RAM then upgrading to AM5 is not necessary. AM4 supports up to 128GB, while DDR5 can do 192GB or 256GB.
For 3D modelling work, a 5900 beats a 7600 or even a 7700 if the work is fully multithreaded.
My basket at OcUK:
Total: £640.81 (includes delivery: £11.98)​
MAy i ask what the difference is between an A620 and B650 motherboard?
They're meant for CPUs categorised as 65 watt, don't have PCI-E 5.0, usually have less M.2 slots (1 or 2, whereas B650 is more likely to be 2, 3 or 4) and don't support overclocking. You're also likely to have more basic sound & less speedy USB ports.
you're missing a gpu as well, the 3700x does not come with an igpu
£10 for a GPU that can run Windows 11, hmm...
