Upgrading my PC, help me please
8 May 2012
I created a thready earlier but it disappeared for some reason.
Can I just for some advice about upgrading my PC. It's a bit slow and want to upgrade the GPU as well if possible.
Spec:
Q6600
P35 DS3R
2GB 800MHz
8800GT
I was thinking of adding a SSD and changing RAM and GPU.
Can you please recommend me compoenents that are compatible. My mobo supports DDR3 but I am not sure how well.
Thanks
Depends on a few things.
PSU : Needs decent quality to support a 6850 (which would be my minimum recommendation, £100).
Looking at the spec sheet and supported memory list, your motherboard doesn't support DDR3. 2GB is a huge bottleneck.
Overclock the Q6600. Get a decent cooler.
EDIT : hmmm some people have fitted 2x2GB DDR3 rams with that board?
