This is my current setup
CPU - Intel Core 2 Quad Q6600 @ 3.2GHZ
CPU Cooler - Big Typhoon 120 VX
Motherboard - GA-EP45-UD3LR
PSU - OcUK 650W Dual-Rail High Efficiency Power Supply
RAM - Kingston HyperX 4GB (2x2GB) DDR2 8500C5 1066MHz Dual Channel
Graphics card - Gainward GTX 260 @ 725mhz
Display - 22" Samsung SM2233RZ LCD 120hz + 3D Vision
Sound Card - ASUS Xonar DS 7.1
2GB Readyboost USB Flash Drive
Hard Drive - Samsung 750GB
Logitch G9 Gaming mouse and Razer Destructor Mousepad
Not the most expensive or up to date but it actually runs extremely well. I can play any game and max most of them.
However, I want to upgrade.
CPU - Motherboard - my motherboard is still quite new so i'm thinking of simply getting a Q9650 and OCing to 4ghz rather than getting an i7. I don't know much about i7s so I don't know which cpu is best or which motherboard is best or even if the motherboard would fit my case!
http://www.overclockers.co.uk/showproduct.php?prodid=CP-231-IN
If someone could tell me if it is worth getting the Q9650 or if I can get an i7/motherboard which fits my case and will outperforms it that would be excellent!
Graphics card I want to upgrade but I want to get somethign that's not too expensive yet will last me a long time and perform extremely well. I've gone for the
http://www.overclockers.co.uk/showproduct.php?prodid=GX-142-GW
What do you think? There should be no power issues should there?
Lastly i'm going to get another 4gb of kingston.
Really would appreciate some help on the cpu issue. I'm confused as what will be best to do.
