Upgrading my system...
Do you have a better CPU cooler than the stock intel one?
Depending on the cooler you may run into problems with that RAM because of the height of its heat-spreaders.
With that exception they would work fine.
Of course if you need both of those you could sell your i5-760 and go for a sandy-bridge build?
According to the motherboard specs it supports 1.65V RAM. You have picked a 1.5V set. If you can ensure that the board is 1.65V (and not a typo) i'd play it safe and get some 1.65V RAM.
Why are you going for 1866Mhz, i think 1600Mhz should be enough.
Yes i do, i purchased an overclocked game titan about a year ago, the mobo is faulty and im sending asus it back hence why i am upgrading, this board is better than the current P755M. I cant remember the CPU cooler but OCUK had it clocked to 4GIG using it.
upgrade
What memory would you recommend? The 1866mhzz stuff with that voltage is on pre-order and i really would like something in stock.
I looked at the 1600MHZ, price is a lot cheaper! I am even thinking of getting this x 2
http://www.overclockers.co.uk/showproduct.php?prodid=MY-290-CS&groupid=701&catid=8&subcat=1517
16GB!!
Doesn't matter what voltage RAM you get, you can set it to the correct value in bios. I've run 1.5v and 1.65v with my i5 750 with no problems.
Edit: the kit you've linked to above will work great :) There's no need for 16GB unless you're doing some serious 3d rendering though. 8GB is already overkill for nearly everything.
