Upgrading old pc
20 Feb 2004
Hondon de las Nieves, Spain
Hi Guys
I’m looking at upgrading an old Dell P4 1.8ghz pc.
Its not going to be used very much to be honest other than basic duties, however I plan on using it to organise and control my music, my library is around 70,000 which are stored on my server. I’ll be planning on using itunes as I have a plug in which helps sort out the metatags which tends to be quite power hungry and took quite a while on my laptop. i’m also likely to be converting FLAC to MP3/AAC for use on my ipod as and when I need it so not sure how much computing power that would take.
I’ve not really kept up to date with computers for about 4 years since I had my old Socket 939 3000!, however I did build an Atom based server about 6 months ago, so I feel confident in doing the work myself.
I’ve had my eye on an AMD 5200+ AM2 bundle in the MM for about £65, it comes with an Abit motherboard which has HDMI onboard graphics which would be ideal for me as it’s being connected to a 32” LCD tv.
Is this likely to be enough, or should I be looking at something a bit bigger for the odd times I might need extra power.
Also I recall the old P4’s being pretty power hungry, am I likely to be able to use the same power supply that’s in the old pc since these newer chips seem more efficient?
Yeah pretty much any dual core bundle should be fine for your uses.
This is about the cheapest you could get something new:
AMD Athlon II X2 Dual Core 250 3.00GHz (Socket AM3) - Retail £41.99
(£34.99) £41.99
(£34.99)
OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C8 1333MHz Ultra Low Voltage Dual Channel Kit (OCZ3P1333C8ELV4GK) £35.99
(£29.99) £35.99
(£29.99)
ASRock N68C-S UCC GeForce 7025 (Socket AM3/AM2+) DDR2/DDR3 microATX Motherboard £33.98
(£28.32) £33.98
(£28.32)
Sub Total : £93.30
Shipping cost based on delivery to paypal address, with:
FREE SHIPPING (DPD Next Day)
(This can be changed during checkout) Shipping : FREE
VAT is being charged at 20.00% VAT : £18.66
Total : £111.96
Else just ask in the Wanted section for a Core 2 duo or cheap AM3 bundle, should have a few options for £65-80.
How about AM2? Or for future proofing am i best sticking with AM3? Are there much improvements on the platform?
Well DDR3 is cheap these days so you might as well go for AM3, also the dual core AM3 Athlon chips can be had for about the same price as the first generation Athlon X2s.
Quote...
All of the brand name manufacturers have experimented with proprietary designs over the years, including special power supply connectors, odd sized motherboards, and unique motherboard I/O cores that will only work in a particular case. You can always hack your case up and make it work by changing enough parts, but there's little point when new cases are so cheap and used PCs are a dime a dozen. If your Dell or HP uses a proprietary power supply connector for the motherboard, that's a reason not to upgrade the motherboard. Compaq use to be the worst offender when it came to proprietary design, which probably means they had the best engineers:-) The early Emachines I worked on were also pretty inflexible, but I recently worked on Emachines that had been upgraded with a DVD recorder and a second hard drives. The reason I was called in was the power supply had died, but it took a standard ATX replacement. I also worked on a brand-new high end Dell just a couple weeks ago that had no IDE connector to accepts the hard drive from the computer it was replacing as a second drive. The new Dell was strictly SATA, it didn't have any free IDE capacity.
http://www.daileyint.com/hmdpc/pcs.htm
Check it all fits with case & psu.
Thanks for that, i'll take a look inside it tonight and see what the script is.
Redmint, thanks for that. If i'm buying a bundle in the MM though which is fairly cheap is there any reason not to go with it and look for an AM3 bundle, performance wise?
For encoding some music and basic tasks you won't really be able to notice much difference between AM2 and AM3 tbh.
