Still with a target of getting my system as quiet as possible, will a single D5 pump cope with a CPU block, a GPU block, 1 x EK CE280, 1 x 280 Nemesis GTS and 2 x 240 Alphacool ST30?
I am thinking if I am going to break the loop down, I may as well only do it once.
I have some 5.25” bay adaptors coming for my 3.5” HDDs so I can free up all the space at the front of the Enthoo Primo for radiators. This will effectively add 480mm of radiator space, and if that is not enough, then I don’t know what would be.
It is probably overkill, but if I can have the fans just ticking over at 800rpm, then it should be pretty quiet.
My only concern is flow rate through the loop on a single pump, with all the restrictions in place.
I have a few days off work next week, so it is the ideal time to fiddle with my system, as I am changing the Z390 Aorus Pro out for a master to support a better OC.
Great, thanks for the info.
I have coolant temp at 35 degrees before I overclock the CPU. Due to the radiators I have, at this temp, the top radiator (gts) fans are running at about 900rpm, and the bottom EK CE) at 1300 rpm. I think I may knock the fans on the gts up to 1100, and double check my pump speed.
I am still tempted to pop another rad in the case though. Probably just one.
The EK PE 240 looks pretty good in push at low to medium fan speeds.
I will fiddle a bit more before deciding which way to go tomorrow.
Sounds about right if you mean while idlingInterestingly, I have a delta temp of +10 degrees compared to the ambient temperature in the room.
Imo the GTS is a much better rad that the PE. That being said, it's very restrictive.
I thought so as well, but that is not the case in the 280mm size.
https://www.xtremerigs.net/2016/02/14/alphacool-nexxxos-st30-280mm-radiator-review/5/
