- 4 Nov 2012
Can you change the PSU from a prebuilt Acer Predator Orion 3000 (500w PSU installed) to a more powerful one to run a better GPU? If so how easy is it/and what would you suggest sticking in it?
It looks like it is technically possible, but the connectors are proprietary, so you'd need at least one adapter cable and reports (from a google) are mixed about how successful this is.Can you change the PSU from a prebuilt Acer Predator Orion 3000 (500w PSU installed) to a more powerful one to run a better GPU?
Any suggestions on what PSU and adapter to get? Prob would like to go what 650w-750w, doubt price difference would be too different.It looks like it is technically possible, but the connectors are proprietary, so you'd need at least one adapter cable and reports (from a google) are mixed about how successful this is.
What graphics card are you trying to upgrade? It is possible that you can still achieve something with the stock PSU and a single 8-pin PCIE connector (assuming that is present).
You should be able to find some of the posts on reddit (and elsewhere) and read about user experiences with this type of upgrade.Any suggestions on what PSU and adapter to get?
I could make it go kaboom you mean lol. That would be a story wouldn’t it. I fry my eyebrows off due to a recommendation from TetrasYou should be able to find some of the posts on reddit (and elsewhere) and read about user experiences with this type of upgrade.
I would not want to recommend anything, because this is all unofficial/modding-type territory with big potential for issues/frying stuff.
From what I can see when googling the possibilities for the motherboard it comes with, no PSU comes with the right cables. You should need an adapter for at least the main 6 pin, of which no official adapter exists. The last example I saw, they used one intended for a Dell, but several other posters said these adapters did not work.I know you won’t recommend anything, but doesGAMEMAX 750W Fully Modular ARGB Power Supply come with the right cables possibly? I am not looking at it for the rub or anything, just wondering if your best guess the cables included could be right?
I may be safest then, just to keep the thing alone, maybe add a slightly better than a 3060 in it (doubt I can go much higher with only a 500w PSU) and then just leave it as is, and put all funds into own build in future.
The best upgrade I can think of with a similar power profile and a single 8-pin connector is a 4070. 9060 XT 16GB is 8-pin as well, but 4070 has more grunt.I may be safest then, just to keep the thing alone, maybe add a slightly better than a 3060 in it (doubt I can go much higher with only a 500w PSU) and then just leave it as is, and put all funds into own build in future.
That's not a problem, power usage of a 5060 Ti is similar to the 3060, but a 5060 Ti would normally have a 16-pin connector.Definitely should not be running a 5060ti in the machine then, will stick the 3060 back in before I blow the thing sky high.
One I got had only 1 x 8-pin connector. But yesterday machine did turn off as it got very warm indeed.That's not a problem, power usage of a 5060 Ti is similar to the 3060, but a 5060 Ti would normally have a 16-pin connector.
Hmm, odd. The 5060 Ti has similar power usage, so I'm not sure why that would happen.One I got had only 1 x 8-pin connector. But yesterday machine did turn off as it got very warm indeed.
