Hello, I was wondering what I should upgrade on my computer with my budget of £300
My current specs are:
Q6600 @ 2.4GHZ
Foxconn G33M Motherboard
6GB RAM 800MHZ
400W Power Supply
9600GT
Antec 1200 Case
At the moment I have bought a new Antec 600W Power supply due to the wires being too short for my Case and therefore I have decided to spend a bit of money on my system. At first I thought to upgrade my memory but the motherboard only supports 800MHZ so that is a problem at the moment.
I have £300 to spend and was thinking of buying a graphics card, either a 5870 or a 6850.
If you have any suggestions on how to upgrade my computer it would be very much appreciated.
Thanks.
Q6600 @ 2.4GHZ
6GB RAM 800MHZ
400W Power Supply
9600GT
Antec 1200 Case
Thanks.
