Upgrading Tiger to Leopard
18 Oct 2002
Lo all,
Is there any reason why my housemate couldn't upgrade his version of Tiger to Leopard on an old iMac using my install disk?
Not sure what the rules are on licenses etc.
Cheers
Panzer
One user per install disk, unless you have a family pack which mean you can install on 5 Macs with one DVD.
Is it a full retail disk or is it one that was tied to your Mac?
Wouldn't work if it is tied to a MBP anyway, as you can only use the machines disks on that particular machine.
Saying that it is only a check sum stopping you installing it on something else, but google is your friend for that, not allowed to discuss it on here.
