Hi all,
I'm looking at upgrading to a 2080Ti from a GTX970, as I need some more power for rendering with V-Ray. GPU rendering seems to be the way to go now! I'm a bit of a technophobe when it comes to PC building, haven't got the faintest idea, so I'm looking for a bit of advice:
1. Would I be able to run a 2080Ti alongside my Zotac GTX970? I'm not sure if the two cards would work together. I know I wouldn't get any more video memory, but the extra CUDA cores would be good for V-Ray, if they worked together.
2. If I just ran a 2080Ti on its own, would I need a new power supply (how powerful?) and/or anything else to get it installed? I presume that I'd definitely need one if I ran both cards (if they'd fit and work together).
I've put my PC specs below, it's now 3 years old:
Many thanks!
Many thanks!
