Upgrading to full frame, advice on what to buy.
Caporegime
12 Mar 2004
England
Due to a big increase in income I can now afford to upgrade from my D7000 to a full frame, I primarily want to upgrade for the ISO performance benefits and the greatly increased sharpness at large apertures when used with FX lenses. Since my current lenses are DX I'll be selling them (in hindsight buying DX lenses was a bad idea) and buying new FX lenses.
I was thinking of buying:
Nikon D600 £960
Nikon 50mm f/1.4 £288
Nikon 80-200mm f/2.8 £616
Total: £1,864
What does everyone think, are there any alternative brands I should consider instead?
I'd like a standard zoom lens, but I don't feel that I don't feel like spending £330 on Nikons 24-85mm when it's aperture is only 3.5-4.5.
I'll also need a flash as I find myself never using a flash because the build in one is too weak be of any use in sunlight and the direct light too harsh to use in a dim environment.
First of all play with a D600 before you buy it, you may not like the AF, second of all what are you shooting that a DX cant take?
I moved from a Canon 6D to a D7100, I hated the AF and have since found the D7100 can go to ISO's up to 5000 ISO before i have to make changes in PP.
I do understand your comment about DOF at large apertures, my Nikon 35mm at F1.8 and Nikon 50mm at F1.4 do not look as good as they would on FF.
As robj20 said
Could keep an eye on the new Sony A7 cameras out soon. Should be a pair of great performers.
but its nearly as much as a D800, granted with the adapter rings you can use your current lenses IIRC, could you stretch to a D800?
As for a flash you may want to look at the Yongnuo YN-565EX, I have it and its a fantastic flash, the only thing it dose'nt have is HSS but that will cost another £50 O_o
Nikon D600 £960
Total: £1,864
First things first is make sure you really want FF, there are at least as many cons as pros so it depends what's you really want or expect. The extra low light performance is only 1 stop, somewhat less than you might expect and depending on your DX lenses easily achievable with better lenses.
For a normal zoom look at the Nikon 24-70mm f/2.8 or 24-120mm f/4.0. But if one of your reasons to moveto Ff is lowlight then you should really be looking at f/2.8 or faster to get any benefit.
Btw, what DX lenses do you have? Some work well on FX, like the 35mm f1.8 DX works as a portrait lens. I wouldn't feel bad buying DX lenses for a DX body, makes more sense than buying FX lenses for a DX body in the wide to normal range.
A7r has a much larger lens selection. They are just either manual focus or you need an AF adaptor.
Due to a big increase in income I can now afford to upgrade from my D7000 to a full frame.
Then I would wait until you have saved enough to really go to town and get the gear you really want.
The choices you highlighted are no better idea than when you purchased DX lenses. It won't be long before you want to upgrade them again.
I think you should state what you will be using the camera primarily for. There is no perfect camera, you need to choose the best compromise
Personally if I was just shooting for fun, I would look at a camera what is fun to use. In my case I would be tempted with an X-E2.
Bang on the money there. If you aren't shooting for money and instead just for fun, just get something you actually like to use. Its what I did and I haven't looked back.
If you are shooting for fun, I'd ditch the idea of the DSLR and go for a fuji x pro 1 (not sure when the 2 is out) or the X-E2 that is brand new. Not full frame, but the lens line up is pretty nice and it offers truly full manual control, just like my leica does.
Full frame is a bit of a gimmick to be honest as the depth of field and iso can be useful, yet the later has started turning a lot of photographers into lazy point and shoot specialists, especially with auto-iso features etc. Most of the time, shooting wide open at large apertures such as 1.8 or larger is also counter productive to the shot as the depth of field will be far too small to get most objects in focus, including peoples faces unless they are further away than the composition would probably like in the first place.
I also wouldn't buy a D600 if you have your heart set on an fx camera, as the autofocus is rubbish compared to the D7000 as the coverage in the view finder is abysmal and its low light accuracy is poor unless you use the built in autofocus assist lamp, which isn't ideal for subjects such as wildlife etc. I've owned the D600 and my fiancé owns the D7000, so I've had a good go at comparing these side by side and can safely say you'd not gain much going to the D600 in terms of usability and image quality. Either get a D700/D3 if you are concerned over the budget, or get a D800, as any of those choices are better from a usability perspective than the D600 is.
The D610 might be a better option as it has fixed the mirror box oil issues.
What are these mirror box issues? Is it worth the extra £150?
What's wrong with the AF? Typically I only use a single af point.
I'm mainly shooting indoor sports, so the lighting isn't the best and the shutter speed high.
As robj20 said but its nearly as much as a D800, granted with the adapter rings you can use your current lenses IIRC, could you stretch to a D800?
Possibly, I mean I do eventually want to move beyond the D600 to the higher ISO performance of the D800 anyway and the ability to change the aperture in live view means I wouldn't have to keep using D lenses to shoot video...
I'll take a look at the Yongnuo thanks, as a couple people in this thread seem to be recommending them.
What DX lenses are you selling? :) I am considering buying a long zoom.
I currently have a 35mm f/1.8 and 18-105mm f/3.5-5.6, ironically I've already sold my only FX lens, the 70-300mm f/4.5-5.6 because of it's narrow aperture. Experience has shown me I don't need that much reach anyway.
Yeah I took a look at the 24-70mm but I don't think it was worth the money for a lens two stops slower than the 50mm when the focal length range is not hugely different if a take a few steps towards or away from the subject.
Is there any point keeping the 35mm f/1.8 though if I'm getting the 50mm f/1.4?
But for me an SLR is fun to use. :D
I have done some small jobs for money in the past though, and hope to step that up a bit, nothing major though.
I don't feel I need a large DOF for what I'm shooting though, the calculators seem to suggest that it would be more than adequate in any case.
Maybe the D800 will be a better choice for me after all then, I'm amazed that the AF is considered so poor for a camera in this price range, why would Nikon release a POS only to have the prosumer and professional buyers subsequently return it?
It's AF is not a POS. It's just nowhere near as good as a D800/700 if you are someone who doesn't focus recompose. The focus recomposers will get along fine with the camera. They don't know or are not used to working any different in any case. (of course nailing focus is more challenging for them)
I might out a D800E in members market soon, if that interests you. Quite fancy trying a x-E2 and a 23mm 1.4 personally or even tempted with a Leica 240.
