- 12 May 2005
- Cambridge, or somewhere else in the world
Hi guys,
I'm about to rebuild my system and want to upgrade my water cooling solution. At the moment I'm using a Zalman Reseterator v2 (the black one) which I originally bought to cool my media centre pc. For reasons I can't be bothered to go into the mdeia centre is currently cooled by air and is way too noisy, so the Zalman system is going back into that.
So, my first question: Which is better parallel or series?
If I were to put it into series it would be:
>Res>Pump>CPU block>GPU block>Rad>Res
In parallel it would be:
>Res>Pump>Tbar>CPU block>Tbar>Rad>Res
...................>Tbar>GPU block>
Is there any benefit to this second setup? Pitfalls?
My current rig (in bits atm):
Q6600, 4 Gb Corsair XMS2 ram, Radeon 3850 Pro, Abit XI38 QuadGT motherboard, Akasa Eclipse
My proposed watercooling:
XSPC Edge Acrylic CPU Waterblock
or
EK Supreme Clear Top
XSPC Dual 750 Bay Reservoir & Pump
XSPC RS240 120mm Radiator
and associated bits: tubing clips, barbs etc.
Which cp block is better? I saw on another thread that the edge block is a better pairing with the res/pump. But it's out of stock atm and I need to get on with getting my rig back in use. I intend to do some reasonable overclocking.
Oh, I've already got a suitable block for my graphics card.
Many thanks
Chris
or
Many thanks
Chris
