- 4 Nov 2005
I have 3 Vista PCs in the house:
1. Mine as specced below. Mainly used for FSX, il2, Hearts of Iron 3, as well as normal duties.
2. Media Center in the lounge - E2160 - mild oc to 2.4Ghz so as to keep the noise and heat down.
3. Family PC. Old AMD 3700+ CPU (really can't remember the rest of the spec). Surfing, children talking crap to other children on MSN and facebook and basic office duties.
Number 3 started getting flaky recently. I wisely saved the data, and last weekend it decided not to boot up at all, or even let me into BIOS. I've done the usual swapping out components, clearing CMOS de da de da de dum.. nada. I'm assuming the board is kaput. There may be a fix, but I can't be arsed anymore and have developed the very common desease on this forum of upgraditis.
The plan:
1. Upgrade machine 1 to a i5 750 jobby, Gigabyte P55 mobo, 4 Gb Dual Channel DDR3 RAM, and a new cooler to support a 4Ghz overclock and stay quiet - c£400.
2. Move machine 1s board, CPU, and RAM into Machine 3, fire it up and hope it works.
3. Upgrade all 3 PCs to Win 7 using the £130 family upgrade deal found elsewhere in this jungle
. Specifically for the new version of Media Center, but also so that SWMBO can see some visible value in the spend.
Questions.
1. Is there a better plan for this c£500 given the usages of the machines.
2. Could you recommend me a quiet cooler, which plugs straight in (no back plate), that will tame a 4Ghz clock on the new machine 1.
Hope you can help.
Thanks
The plan:
Questions.
Hope you can help.
Thanks
