Suspended
- 25 Nov 2007
- London
Ok so since i got my BT infinity connection, after conducting many upload tests it does appear as a single upload is around 6Mb/s at maximum.
My upload speed is around 18Mbit.
If i for example, upload file A to person A, it will go at 6Mb/s.. If i then upload File B to person A it will also go at 6Mb/s And then file C to person B also its 6Mb/s (all at the same time).
Speedtest.net seems to be uploading @ the maximum, also Google drive.
What software can i use that will support multiple connections to the same person, same file, so i can always upload at max speed?
I've had a look at filezilla but from what i gather this option is removed due to overheads?
definitely something on BT's end.
