Here it is (configs.inc.php) :
<?php
Unless specified, 1 means yes/on and 0 means no/off
$UPL['CONFIGS'] = array
// THE TIME FORMAT USED TO DISPLAY FILE UPLOAD DATE
'TIME_FORMAT' => 'm/d/y h:mA',
// Other time formats
'TIME_FORMAT2' => 'm/d/y h:iA',
// Simple time format
'TIME_FORMAT3' => 'M d, Y',
// SET THE DOMAIN PARAMETER OF COOKIES SET BY THE UPLOADER, IN MOST CASES YOU'D WANT TO LEAVE THIS ALONE
'COOKIE_DOMAIN' => NULL,
// MUST BE IN THIS FORMAT 0xxx where x is an octal number. If 0755 doesn't work, use 0777 or 0666
'CHMOD_TO' => 0777,
// Set the position of the watermark image to either top of bottom of the original image. 1 for TOP, 0 for Bottom
'WATERMARK_TOP' => 0,
// Same as above, 1 for left, 0 for right.
'WATERMARK_LEFT' => 0,
// max folder name length
'FOLDER_MAX_LEN' => 30,
// min folder name length, should be at least 1
'FOLDER_MIN_LEN' => 4,
// max file name length including the extension
'FILE_MAX_LEN' => 80,
// min file name length including extension, should be at least 5
'FILE_MIN_LEN' => 5,
// default file list sorting: 'none', 'name', 'type', 'size', 'date'
// Note: the default template tpl_myfiles.php sorts the files by date through javascript, so this option doesn't apply unless
// you disable the sorting by editing myfiles.js.
'DEFAULT_FILE_SORT_BY' => 'none',
// default file list sorting order: 'asc' or 'dsc'
// Note: same as the setting above, you must disable the javascript sorting in order for this setting to apply.
'DEFAULT_FILE_SORT_ORDER'=> 'asc',
// invalid characters in file name. Regex pattern
'REGEX_INVALID_CHARS' => '#[\\\/\:\*\?\<\>\|\"]#',
// These folder names are reserved. Users cannot rename or create folders with this name.
// Enter folder names in lower case, checking will be case-INSENSITIVE.
'RESERVED_FOLDERNAMES' => array ( 'thumbnails', 'main folder' ),
// Default message inbox size
'DEFAULT_MAX_MESSAGE' => 20,
// How many users to show per page on the Browse page.
'USERLIST_PERPAGE' => 25,
// Width of thumbnails after upload, height will be adjusted
'THUMBNAIL_WIDTH' => 150,
// Add border with original image info (dimension and width) to thumbnails?
// This applies to any thumbnail created, either during upload or manual resize by user.
'THUMBNAIL_BORDER' => 0,
// Skip watermarking images with width less than this (in pixels)
'WATERMARK_IGNORE_WIDTH' => 200,
