- 7 Nov 2005
- Southampton, UK
Hi,
I'm downloading the WoW trial through the Blizzard downloader and it says that I'm behind a firewall, what it is mistaking for a firewall is NAT, my router.
I do not own or admin this router unfortunetly and I can't get the password, he won't give it to me.
However, the router does support UPnP and I use several apps which use it successfully.
My question - is there a tool which will allow you to open and close ports via UPnP which is not build into an application?
e.g. load app, type "10800" in open port field, click open, port 10800 is open via UPnP.
Thanks
Thanks
