UPS manufactures cutting corners
17 Dec 2004
I have a 1800watt/2000VA Online UPS and was quite shocked to find that all 4 outlet sockets are using the same 3 wires and not using individual wires for each socket:eek:. So spreading out the load over the 4 sockets is pointless.
Why would that be a problem?
The multiple sockets on the back of a UPS are purely to plug in multiple devices (essentially just a built in power strip), but you still can't exceed the total Watt/VA limit.
1800Watts is less that 8 Amps - even 1mm cable cross section cable would be fine, but likely it will be 1.5mm or even 2.5mm.
