- 2 Sep 2013
Hello all.
It's not quite PC Power Supply related, but sort of is at the same time (my PC is plugged into one at the moment I guess). Got a quick query or two:
Quick history:
About just over 3 years ago (so no warrant and free replacement anymore), I obtained an APC Back-UPS ES700 from Overclockers. Obtained it for express purpose of keeping Modem (TP Link W9970), 8 port gigabit switch, standard cordless landline phone, and NAS (Synology DS215J) powered during power outages at my parents place. At a very minimum to keep the landline phone powered in case of emergencies. Cue a few weeks ago, and it (ES700) began to beep like crazy.
Diagnosed the issue as possibly being simply needing to replace the battery. This isn't an issue, it's around £40+ for an official APC replacement direct. The only issue is, the current battery went from 100% normal function to 0% (and charging) just like that as far as I can tell. So I'm not even certain a replacement will work; as in, the unit itself may be cause of the battery issue. So if I obtain a replacement battery, and it turns out it's the unit itself, I'd need to fork out for more, and I might as well go via APC direct at that point. (Trying to save on costs)
An alternative is to use their Trade UPS program and purchase something else (or repurchase it again). The issues here, are, the prices are stonkingly bad. Like, I could shop at Overclockers and obtain three for the price of two direct via the Trade-UPS program. But I don't want to keep going for a unit that's going to need replacing every few years potentially if I can't be certain replacement batteries will sort the problem, or if the UPS battery can't be replaced (which supposedly some of them are unable to be done so).
So the full set of questions I have now:
1. Is there an alternative UPS or something similar that I can use for the express purpose of keeping the phone alive if the power goes dead? It uses a standard UK 3 Pin plug, so something that supports that will be great.
2. If I take advantage of the APC Trade-UPS program, I really only need the four main items listed above able to be powered and kept up for a bit until power cycles back up. But looking at the APC (proper) UPS available, the ones that would be able to do the job carry the iec or whatever standard of sockets. So I'd also need to obtain the appropriate plugs/adaptors/etc for use with them. But what I'd like to know is, would I need to have an adaptor for each socket on the UPS for each device? ie. Phone to its own socket, switch to own socket, etc. Or can I get an adaptor that lets me plug in more than one device into one of those sockets?
3. Incidentally, I have fairly good hearing. And the current ES700 had a very low volume, but high pitched whine when its on. Almost imperceivable. Think it's part of the power switch circuitry inside, but annoying still to my ears. Anyone know of any devices that are silent? Or are they all like that?
Thanks for any help everyone.
PS. Mods, if this is in the wrong section (and likely is), please move to the right one. Thanks.
Quick history:
