- 1 Oct 2005
Hi People
Does anyone know of a upscaling lead that will work with the Playstation Vr headset.
I know the headset has a fixed resolution, but have been looking on youtube for a way to sharpen or clean up the image. Upscaling may be a way foreword, unfortunately the one I liked the look of (Seiki) is now not available in the USA or UK.
https://www.amazon.co.uk/Seiki-SU4KC1-SEIKI-U-Vision-Cable/dp/B00IE5C6LO
This one is also an option,
The problem is when I went to Amazon some people say it works, some say it’s a waste of time. e.g
I have used this with ps4 and to be honest...... money well wasted!!!!!! cont see the different at all and I switched from stander HDMI to U-Vision HDMI. a rip off. DON
By BES. on 19 June 2015
Didn't upgrade to 4k but it did improve the quality of the image. Personally I thought I got value from that alone.
By David on 22 February 2015
Its fine my friend brought his ps4 round last night looked good just like my ps3 does ,I've only got a1080p TV Though ,but my ps3 looks great and destiny looked great on my TV
By a wileman on 22 February 2015
So I figure the Overclockers community may help. If someone is using something that works and shows an improvement would you please post a link, thanks.
