Hello and Good morning overclockers 2 days ago i builded my new pc and my plans was stable oc to maximize its performance.
My build is
cpu:fx-8350
mobo:asus m5a99x evo rev.2
cooler:noctua nh-d14 max rpm without the low noise adaptor that reduces the rpm.
psu:corsair cx750watt bronze 80+
ddr:ddr3 hyperx kingston 1600mhz 9-9-9-27 1.65v
vga:sapphire 7870 xt
case
verseer rx-i snow with currently 4 fans this week ill install another 2.
Ill give you a view of my current overclock and my settings.
Stable oc is 4.5ghz-1.45v according to OCCT 1 hour of testing. My temps with core temp 1.0 rc 5 showed up 65c max but most of the times it was stable 58-59c with prime it was 62c , when idle the temps are 16c.
My bios settings is multiplier 22.5
CPU/NB freq auto
HT freq auto
i have disable all the power saving options including the cpu config options all are disabled.
I have inserted manually the ddr timings and voltage.
I have a feeling that my temps with this bestial cooler are high or they seem ok?
i added like a tiny dot in the center of the cpu like 2 small rices and i installed the cooler.
Im rly upset cuz i see reviews that they get like 4.8ghz stable with air coolers, the noctua nh-d14 have been reported as equal as the h100 from corsair , i dont get why such high temps and such low oc.
Am i doing something wrong? is there anything that can improve my overclocking, im not so familiar with the UEFI bios im not sure what to change and what not, i rly need some help to improve my overclock and be happy with my new build.
Thanks for reading and i hope you can help me.
Jim from Greece.
My build is
cpu:fx-8350
case
verseer rx-i snow with currently 4 fans this week ill install another 2.Ill give you a view of my current overclock and my settings.
CPU/NB freq auto
HT freq auto
Jim from Greece.
