Upside down Lian Li case
29 Jun 2004
Hi, I'm looking for a Lian Li case or other high quality cases that have the window panal on the right hand side in effect, turning the whole case on it's top.
Do these exist?
just remember 1 thing about btx tower like the Lian li V series is the if ya M/Board has heat pipes instead of heat blocks/sinks < the heat pipes might not work as well as they should being upside down ..
i have a V2100 an V2100+ towers an i have make sure that all my MB are not heat pipe cooling for this reason ...
plz correct me if iam wrong but this is what i was told ...
There has been various debate on that point Mav - Many boards are litrally just a copper pipe nothing more - these work fine in any orientation. I'm a bit out of the loop at the moment but when I remember originally read about it most boards were absolutely fine upside down.
Heatpipes rely to evaporation of liquid and then convection of that gas to cool end of heatpipe where it condenses and heated less dense matter tends to move upwards and cool liquid downwards so there's surely at least slight effect from reversing directions.
(without heatpipe's inner surface being coated by fine mesh for capillarity there would be "major" problem)
Most inverted cases just lack active exhaust at top where heat/warm air rises so that's probably bigger problem.
Get an A05B and do what i did.
Cracking case and the isde window i cut myself.
