Caporegime
- 13 May 2003
- Warwickshire
Ever since we moved into our current house two years ago, we've been unable to leave by the back door since it only locks from the inside.
The key won't even go in and the pin doesn't budge.
Knowing almost nothing about locks, is this by design or is my lock faulty?
From the inside, it locks just fine. You lift the handle up to engage the bolts and the key goes in and turns perfectly smoothly.
From the outside, I can see what appears to be a brass pin, but it's stuck and won't move no matter what. I tried depressing the pin with a narrow screwdriver and it won't budge. I've put wd40 and 3 in 1 in there, no change.
So is this by design?
Thanks.
Thanks.
