uPVC Front Door Draught
2 Jul 2004
Hi,
Got a uPVC front door on which the multi-point lock failed a couple of years ago and hasn't sealed the same since the multi-point lock was changed.
It's been letting through a draught thats losing me too much heat.
The top and bottom of door has throw bolts.
The way the door seems to operate is that if you simply push (or pull) the door closed it will latch but remain open slightly - there would be a gap around the door. Lifting the handle up engages the multipoint locking system which pulls the door further in which should seal the gap but doesn't seem to be doing so all the way around.
The door keeps are already at their maximum setting to pull the door in and lifting the handle up is already stiff as a result.
Any ideas what I should do to stop the draught?
It sounds like the rubber gasket might be worn out. Is it the type you can replace or is it welded to the plastic? If you can remove it have a look at the profile and see if you can get a new seal from a PVC doctor type site or ebay. You might even be able to get a thicker seal than the one you have. If you do replace it, replace the internal and external at the same time.
Should be 2 screws on the latch plate on the frame to adjust
If the are already at max then you might need new rubber seals or hinges adjusted
