Hi,
We need to get uPVC double galzing sorted out and so we have just had a rep around tonight for a look and then a quote later.
We moved onto the soffits and fascias where we have some rot which I patched up quite successfully in 2005.
There will be rot in there somewhere as it was difficult to get it all out in spite of treating it with the relevant fungicides.
When we were talking about the fascias etc the guy said that they would just clad over the existing wood. I asked about the potential for rotten wood being trapped under the uPVC. The chap suggested that I should tell the fitters where the rot was and this would be replaced with good wood before being cladded over.
My idea was to replace all of the wood etc with uPVC to avoid any issues where damp might get in between the wood and the uPVC.
I am basically looking for "fit and forget"
Is this idea of cladding over existing materials a bit of a dodge to an easier job as I do not want problems in the future.
So if there is anyone with direct relevant experience please let me know your thoughts. I am not looking for a cheap job but a good job at the right price.
Cheers, PeterT
Cheers, PeterT
