- 12 Jun 2007
- East London
With winter approaching I thought i'd check my UPVC window seals for the first time in my flat. I shoved a bit of paper in each corner of the window and closed it to see if it could hold the paper in place i.e. the seals were good. The lock-side of two windows is not great. Can hear traffic sound through it, bit of flicker when holding a lighter flame up to it, and doesnt hold the paper in place.
Youtube DIYers made adjusting the compression of the lock easy.. but when i thought i'd see an allen key that needed tightening.. i actually saw this nub
https://imgur.com/1ZN0mV8
One would assume these can't then be tightened and seal better? Nothing on the receiver end either.. just a metal shaft and 2 screws into the frame to receive it. The nub can't be tightened either.. the outer metal ring just rolls loosely on all my windows - not just the crap-sealing ones. No brand/model on it to look it up either. Didn't realise they made these so you couldn't adjust but i guess i'm looking at a replacement mechanism or am i missing something?
