ur advice please =]
7 Apr 2009
leicester, uk
im gonnna be buying upgardes for my pc very soon from here but my current motherboard wont handle the proccessors so i have been reccomended this motherboard http://www.overclockers.co.uk/showpr...d=5&subcat=808 but i was just wondering if i replace that and my processors from a 2.2 duo to the 3.0 quad (both am2) would i need a diffrent power supply? and would i need to get a new case maybe one with a better fan?
What PSU are you currently using and what components will you be using in your upgrade.
Also the link in the op just goes to the homepage.
open up your case and see if there's a make/model on the PSU (the box that the mains lead connects to the back of) if there isn't I would recommend getting a new one regardless of what wattage it's rated at, as unbranded PSU's tend to fail unexpectedly often taking other components out with them.
Its a good processor/motherboard combo that you've chosen though.
rated wattage is the key figure really (400W/500W etc)
It would also be useful to know what other components you have (graphics cards and the like)
EDIT - beaten
i have a geforce 7500 graphics card wich is gonna be replaced soon errr what other compnents are u refering to? i think mine is a 250 watts one cuz it says total output continuous shall not exceed 250 watts
What size is the motherboard in current case, there are two form factors ATX and M-ATX if it's the later then a new case would be needed.
If your after changing your your case have a look at the Lian-Li range or the Antec 300.
