Urban Exploration - Asylum!
Caporegime
8 Sep 2006
On Ocuk
As per your other thread the chromatic aberration really stands out in these too.
What camera are you using? There's something that doesn't sit right with me in terms of processing. A lot look quite normal - if that makes sense - almost like estate agency photos.
I would personally try a shallower depth of field and with these I'd opt for a slightly desaturated look too, whereas it looks like you've upped it.
I like the model ones in terms of the idea but again a shallower depth of field would help. Not sure about the pen/veins on the legs though :p.
Having the 'actress' in there just makes it look like a cheap halloween outfit advert to me (I mean no offence, but it just looks tacky).
The non-person ones look grand though.
Check out photographer jason lanier as he has done a similar photo shoot with a model in a run down building.
He tends to keep the lighting fairly simple.
Isn't it because of the the HDR effect going on !!
The photos looks good, but over processed IMO.
