Ok for a few months my PC has had some real problems, At first i thought it was my ram that was borked after i ran the memtest program it found thousands of errors, So i purchased some new ram and the problems persist.
The problems were a few things like rebooting at unregular intervals, Programs crashing like my firewall keep shutting down, Plus if i was using the net it would crash and the Dr Watson post debugger would do something? I cant play games as they just crash. Like i have Battlefield 2 and if i try to patch it, It fails but if its been off for ages it will patch ok.
The PC would run fine for a bit if it was switched off for a while, Like if i downloaded something that was rared it would say it was corrupt, Then if i shut down for about 2hrs it would then unpack fine.
So i just ran a PC-Doctor program that came pre-installed and i ran loads oftests that were fine, Until i tested my graphics card and the memory test failed giving this error code --> VC316-1W
This is my PC specs
HP A1128.UK
XP HOME SP2
Akasa 400w Paxpower
AMD64 3000+
1GB PC3200 Super Talent
160GB Samsung HDD
MSI MOBO?
ATI X800GTO2 LE
So does it look like my X800GTO2 could be to blame for these problems? As if it is, Then i can take it out and put my old PSU back in. And then go back to onboard graphics
Any help would be great as i need it
And sorry in advance for my terrible typing
This is my PC specs
HP A1128.UK
XP HOME SP2
Akasa 400w Paxpower
AMD64 3000+
160GB Samsung HDD
MSI MOBO?
ATI X800GTO2 LE
