Hi,
I'm putting together the motherboard for my new computer. I've installed the CPU (Athlon 3800 64 X2) onto the motherboard, and now I'm trying to install the heatsink and fan. I've got some Arctic Silver compound for this, and the instructions state that compund should be used. I have the retail kit so have the standard AMD fan. It looks like there is some kind of thermal pad on the base of the heatsink, and the instructions per Arctic Cooling say that any heatpads should be removed. Should I remove this from the heatsink?
Also, I have just offered up the heatsink and fan to the CPU to check how to attach it before applying compound, and it has left aresidue on the top of the CPU from the heatpad! I presume I now need to clean this off.
Please can you advise me what to do next, as the instructions aren't very clear. Thank you.
