Hi there guys and gals. I've been looking at the zalman 9700 to sort out my cooling issues.i was just wondering whether anyone knows if it would fit in my case with the combination of components i have...essentially, its a
>thermaltake tsunami with side window and small fan
>asus p5w dh
>intel c2d e6600 (not overclocked)
i'm currently using the stock cooler, which doesnt appear to be doing its job properly. from what i have read, idle temps should not be higher than 55 degs or so.
i'm assuming that if i were to go ahead with the 9700, i would have to remove the MB, which would give me a chance to re-wire everything, cause its such a mess in there
. does anyone have any tips regarding ideal wire routing techniques? e.g. ive seen some people put the wires underneath the MB. is this possible with my set up? (i cant remember cause i wasnt building the system at the time). also, ohw about thermal compound? the 9700 comes with some kind of liquid...will this suffice?
if there are any other recomendations for similar coolers, please let us know...the maximum im looking to spend is £50, and i would like a balance of quietness and low temps (if its not too much to ask)
any help on the matter would be much appreaciated.
>asus p5w dh
