URGENT - display problem in topspin2
28 Jul 2003
South Wales
Trying to play top spin 2 on my sony HDTV.
It's set to 720p and shows as being in 60hz. When you try and load the game it says it doesn't work in 50hz so please change the settings to 60hz in the display settings.
Any ideas?
Stolen from another forum this may help,
"Everytime I put top spin 2 in the 360 drive it said: THIS IS A PAL 60 ONLY GAME please go to DISPLAY and change it.
So I went to display and there was no option on my HD plasma for 60 hz, even though it supports 50 and 60 htz.
To change it this:
1. connect your 360 to your tv via the scart or composite input (remembering to swtich the cable to TV not HD)
2. Start your 360, and go to the display options, you can now switch to pal 60.
3. Now you have done that, reconnect your 360 to the TV via your component cables and switch the cable back to HD.
4. Start your machine up and play top spin 2 or DOA 4 in amazing HD detail!!!!
This is some kind of bug that is present in the 360, even though the game displays in high def when using the correct cable, for some reason it still checks the pal settings before booting, once this has been changed it will be ok with all other pal 60 games too."
To change it this:
you're a star! thanks very much!
:D
