Urgent!! Do i disconect the battery?
Depends if the lighter is live with the ignition off or not, to be safe i would say yes, you can do it on a live wire just don't touch the ground thats all :p
Just take the fuse for the Cigarrette lighter from the fuse panel. The same fuse usually does the interior light.
iain.turner said:
Hello,
When i cut threw the cigaret lighter cable do i need to diconect the battery before i strip the wire?
I wouldnt bother just dont let the bare wire short out or remove the cigar lighter fuse. Either are easier than disconnecting the battery.
