Urgent G1 help needed
Hi all,
Got an issue with my G1. It was down to 2% power this morning so I plugged it in to charge and the recharge light didn't come on. I unplugged the charger, removed the battery and plugged it all back in thinking it just needed resetting.
Now, when I try and load it up I get the first G1 Tmobile screen then goes a caution screen? Black back ground with a triangle with an ! in it with an image of the phone underneath.
I can't get it passed this point.
It did get a little damp yesterday while out and some of the keys were playing up last night but after leaving it somewhere warm for a while it all worked fine.
Any ideas?
EDIT: let it load to caution screen, pressed ALT+L to load system recovery utility, went to do a factory reset and got the following:
E:Can't open /cache/recovery/command
--Wiping data...
formatting DATA:...
Formatting CACHE:...
Data wipe complete.
Then i reboot and it still loads caution screen![Frown :( :(](/styles/default/xenforo/vbSmilies/Normal/frown.gif)
oh, and it wasn't updating or anything when i reset it.
Hi all,
Any ideas?
--Wiping data...
formatting DATA:...
Data wipe complete.
