Morning all.
Turned on my PC today to find a loud sound coming from the inside. I thought that it was just one of my cheap fans that had a build up of dust. How wrong i was.
Then the computer displayed "CPU fan not working" oh ****
The CPU was slightly overclocked (a 3000+ winny 939 @ 2.16ghz) with 1.55v. Voltage a little high, but i have a AC64, and my temps are really great (32idle).
The case is now opened, and the CPU fan header is still connected. The AC64 feels normal and in place, although i'm not trusting myself to be certian.
What should i do next. Would resetting the BIOS remove the overclock? I dont care if i loose it, as having a processor is more important
Should i remove the processor and basically start again from scratch?
Sorry if this sounds extremely rude, but the quicker the repies the better, as i could do with fixing this ASAP as i am going on holiday tomorrow afternoon.
Many thanks.
Many thanks.
