Urgent Help - CPU Fan not working!
can you try another fan in the same place? see if its problem with that connection. You could then get a 3in fan to 4 pin power connector and plug it into that
Is this a new build or did the fan used to come on at startup? Reason I ask is because some motherboards have a setting which keeps the fan turned off until the CPU reaches a specific temperature.
Was a dead fan. Got a replacement and works now. Lucky it didn't cause any damage as it was running for about 5 mionutes with no fan until it crashed!
