Hi folks,
Hoping someone can help me urgently. I am trying to connect a LaCie PCI 400 firewire card to my OCuk PC (bought last year). When I installed the card initially my Saffire Pro 40 soundcard was not recognised but it turned out that it worked when I used the firewire port already on the PC.
Anyway, I digress..........I'm presuming the reason why the LaCie card is not working is because I need to connect some internal power to it, and when I tried it previously I had not done this.
I see a small 4 pin white plug on the LaCie and I see an appropriate cable in the PC. Problem......OCuk have the PC so neatly cabled that I haven't got a clue where the other end of the cable should be and it will mean having to break a cable tidy.
Basically HELP!! I know this is basic stuff but I'm sitting here with the PC in bits and would really appreciate some urgent advice.
Many thanks!!
Many thanks!!
