Ok from what I can gather:
If u turn OFF the RGB then press AUTO it goes into some sort of mode which shows only three leds on 1 fan. By pressing the BLUE button on the remote it changes the sequence (example: RED BLUE GREEN, RED GREEN BLUE, BLUE GREEN RED etc.)
I changed it till it matched the order of the colours on the remote and pressed OFF.
Now when I turn it on the colors you press for static are matching the correct colors on the remote.
However sometimes I managed to get only 1 fan, or 2 fans etc changing at a time. I still haven't figured out how I done that but I gave him the PC away to "play around with" so if he finds out anymore info I will let you know.
Also something else I noticed about this case is the jumper leads. There are two that say RESET SW. However one of them is for the RGB button I think it was. I googled it and its a known issue so a pretty big screw up by Kolink.
I didn't have high expectations for this case but in the end I would urge anyone who wants an RGB case to either buy a better brand and fit RGB or spend a little more on a bundle case.
Thanks
