Hey folks, sorry for the stupid title. Needing a bit of advice as I am stressing out here.
I ordered brand new parts just over 2 weeks ago, An Asus X99 Deluxe motherboard, 16GB of Ripjaw DDR4 RAM, Intel 5820K cpu and a GTX 980.
The day after receiving it all, my motherboard failed on me and I had to RMA it with overclockers.
The issue was that it would not start at all, when pressing power, there was no response from the motherboard at all. After a lot of testing I narrowed the issue down to it being the power input for the CPU. My PSU was completely fine as I tested a second PSU and also my PSU in another PC.
It was received at Overlockers on Wednesday 23rd and then after a lot of calls to the RMA department and even raising to managers and even higher than that due to an issue with the RMA being refunded and not replaced (It was a finance order), the issue was sorted on the 29th and my new motherboard has arrived today.
The issue I now have however is that when trying to boot my system, it just, won't... I have narrowed it down to being the CPU and I suspect that it has been caused by the failed motherboard and has broken the CPU also.
When trying to boot now, the system starts up, but when the CPU is installed, no fans will spin (Except from a brief 2 second spin from the CPU fans immediately after pressing power on) and nothing shows on my displays, this is even when the GPU seems to be running without any issues.
When the CPU is not installed, the fans all start and continue to run and the motherboard's CPU LED warning light is on, which is what you should expect.
Now my thought is that the old motherboard has fried my CPU and I feel that I will now also have to RMA this, but that then means that I will be even longer without my new PC and this is a massive issue for me, due to needing the PC for loads of different reasons, some including work.
Would anyone have any advise for things to try before I send this back, or is this the telltale sign of a dead CPU?
