Urgent help needed between 2 panels
13 Mar 2011
Hey guys,
Ready to buy a monitor right now. I'm coming from a 24" 1080p Ilyama PROLITE E2481HS-B1. Wanted to make the jump to 1440p and have narrowed it down to these two monitors:
AOC AG241QG AGON Series Monitor
  • 24-inch display
  • NVIDIA G-Sync, 165Hz refresh, 1ms response time
  • 2560x1440
  • AOC Flicker Free Technology to reduce eye strain and fatigue
AOC AG271QX.
  • 27-inch display
  • AMD Free-Sync technology, 144Hz refresh, 1ms response time
  • 2560x1440
Monitor will be used exclusively for gaming/web browsing, so happy with a TN panel. Card is a GTX 1080, will there be any difference between the NVIDIA G-Synca and the AMD Free-sync?
Thanks for any help. My monitor knowledge is very limited.
So freesync won't work with an nvidia card right? So unless your buying an amd card to go with that freesync monitor you are down to a choice of one..
