Okay I don't understand this and I'm starting to get confused.
I got this cpu (AMD PHENOM 555) and initailly i just put the cooler in (artic freezer pro rev 2) with the paste that came with it, the temperatures kept rising until it got to 47 degrees and i shut it off.
So I ordered some MX 4 and cpu cleaner, i did everything right, watched loads of videos and I had done this before, be it on an intel processor and not an amd but I have.
41 degrees and temperatures rising. What the hell am i doing wrong?
Should i try reseating the HSF again or is this normal? To be fair on the little thing, apart from the cpu fan, its an Fractal R3 and it only has 2 whisper quiet fans to cool. Still, im not doing anything besides watching the temperatures in the BIOS.
Edit again: The cooler is barely getting hot while the cpu is at 40 degrees, could this mean that th hsf is not sitted properly? I dont see how i could have screwed it up considering it has 2 screws to hold it in place and they are very tight. Surely the screws would automatically move it to the best position anyway right?
Thanks for the help
Thanks for the help
