So i'm in the process of building my first PC but somethings not right.
Now i've installed my Extreme 4 Gen 3 Asrock mobo into a Zalman Z9 case and screwed it into place but the allignment seems off.. the IO components are not coming out far enough and i am unable to apply the back bracket of my Antec Kuhler 620 fan to the back of my CPU as half of two of the screw holes for the CPU fan on the mobo are behind the metal of the case.. it's as if the mobo needs to be pushed more to the left but i obviously can't do that else the mobo screw holes would not allign with the standoffs..
Really not sure what do.. it's like the case or mobo has been built wrong or they are not compatible with one another.. :s
Help please!
Help please!
There are two sets of holes, one marked 1155 & other ones 775.
